Hi Everyone,
Has anyone replaced fuel lines on a similar boat ?
I'm concerned about how to pull the new fuel line through !
Looked at how their routed, and it looks like they run through part of the hull ribbing (so can't really access the fuel lines). I was thinking of using the old lines to pull through the new lines, but not sure if this will work (get hung on some bulkhead etc).
Has anyone done this before, and can give some recommendations ?
Greg
Replace Fuel Lines on Cal33-2
Hi Greg,.my recommendation would be follow abyc requirements. Installing appropriate sediment and water filters . Using old lines as feeder for new lines . Coastguard approved fittings .the local coastguard May have a free inspection as well .best of luck Ken
